Autodesk Revit MEP
- Mark Topic as New
- Mark Topic as Read
- Float this Topic to the Top
- Printer Friendly Page
HELP! Face based families hosting at an elevation, not the linked model
- Highlight
- Email to a Friend
At the start of the project, placing a receptacle on the wall was easy, just how you normally do it. Now, we I go to place a receptacle, it automatically has it set for "Host: Not Associated" "Elevation: -92'-0"" "Offset: 0'-0""
How did this happen? How do I get it back to hosting according to the level and the default elevation that it normally works on? Extremely frustrating...
This happened directly after loading a face based receptacle family for floor mounted receptacles.
-crigoli
Re: HELP! Face based families hosting at an elevation, not the linked model
- Highlight
- Email to a Friend
You made sure that your schedule level was the appropriate level, right?
- Highlight
- Email to a Friend
While you are placing an element, you can change the Elevation value under properties before you actually place it. Revit should make the inputted value the new default elevation.
⁞|⁞ Please use the
- Highlight
- Email to a Friend
I am having this exact trouble, where I can set the elevationbefore I place the receptacle, but when I go to the next floor up, it tries to place the receptacle on the floor below. As an example, on the first floor (elevation 0'0") I place the device using the 1' 6" default elevation. When I go to do the same on the second floor (elevation 12' 0") the receptacle Default elevation is now -10' 6" and if I place the receptacle I get the warning that none of the placed item are within this view. If I then go back to the first floor, the receptacle I placed on the second is in the corresponding location on the first floor.
- Highlight
- Email to a Friend
You have to 'reset' the default elevation back to the Family's default, which is accomplished by using the Create Similar command.
⁞|⁞ Please use the
