• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Revit MEP
    Active Contributor
    Accepted Solution
    Flip Control is really good at hiding
    334 Views, 8 Replies
    12-20-2012 01:42 PM
    One of our families created using the Specialty Equipment template is showing up in projects with a flip control in the middle of it.  (3 to be exact)
    I'd like to remove them, but when I'm in the family editor, I can't find the things.  I've gone through the project explorer in the family editor, and looked through all the views, but in none of them can I see this thing.   I tried adding one myself, just to see if it was the control in general, or these that just showed up that are being meddlesome.  The one I added I can find and remove with no issues.
    Any tips on ways to figure out where this thing is residing?
    Please use plain text.
    *Expert Elite*
    Re: Flip Control is really good at hiding
    12-21-2012 06:50 AM in reply to: bashworth
    Can you attach the file here for investigation? And what version of Revit?
    Corey D.        LogoEE.png   AutoCAD user  Revit user
    ⁞|⁞ Please use the Mark Solutions!.Accept as Solution and Give Kudos!Give Kudos functions as appropriate to further enhance the value of these forums. Thank you! ───────────────────────────────────────────────────────────────────────────────────────────
    Active Contributor
    12-21-2012 08:19 AM in reply to: CADastrophe
    Probably would help.  This is Revit 2013, part of the Building Design Suite.
    The three flip controls only show up in plan view when the family is loaded into a project.  In a staggered pattern.
    *Expert Elite*
    12-21-2012 09:14 AM in reply to: bashworth
    Wow - you're not kidding! Even with every element deleted, they persist. Seems like a glitch - was this file upgraded from a previous version by chance? I'm thinking you'll have to recreate it to get rid of those. You should be able to copy/paste the elements to a degree.
    Active Contributor
    12-21-2012 09:33 AM in reply to: CADastrophe
    I was afraid of that :smileysad:
    The geometry is the easy part, it's redoing all the parameters I'm not looking forward to.
    This was made in 2013 natively.  Unfortunately, several hands in the cookie jar, and no real idea when these got added to help me track down what caused it.
    *Expert Elite*
    12-21-2012 09:44 AM in reply to: bashworth
    Well, some of the Copy/Pasting should bring over some of the Parameters.
    Is there a chance that you have a backup (.001) saved somewhere that you could revert to?
    Active Contributor
    12-21-2012 09:59 AM in reply to: CADastrophe
    Was just moving this file into a released status, where we purge any backups, when I gave it a test. (to make sure someone doesn't grab an old version and save over it, or distribute it.)
    I did some asking around, and apparently, the flip control was copy/pasted in from another family.  They couldn't figure out why it wasn't showing up, so they kept repasting it before giving up and adding in one manually.
    Product Support
    alan.quinn
    01-02-2013 01:56 PM in reply to: CADastrophe
    Interesting.....I was able to add more Controls, but not remove the existing. Did you try any of the previous users suggestions. I'd be inclined toward re-building as its not clear how this family got into its current state. Thanks for posting.
    Alan Quinn
    Support Specialist
    Product Support
    Autodesk, Inc.
    Active Contributor
    01-02-2013 02:47 PM in reply to: alan.quinn
    I'm fairly new to Revit, so was hoping I'd overlooked some way of filtering the family elements to weed these out.
    I guess not. :smileysad:
    I'll go ahead and just recreate them.  I'm not going to copy/past anything, on the off chance that I wind up grabbing these things again.  Not ideal, but less time than I fear it will take to perform surgery on these files to remove the problem.
    Thank you everyone for the input/assistance.
