• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Revit MEP
    Active Member
    Flange Family Parameter Formula
    260 Views, 1 Replies
    11-26-2011 08:50 AM
    A Invalid Input error message pop out when creating a flange family following Revit MEP 2010 Families Guide - Metric Tutorials.
    Please help to figure out the reason.
    Please use plain text.
    Product Support
    Re: Flange Family Parameter Formula
    11-27-2011 07:32 PM in reply to: diacreek
    It seems that you entered "Lena2" as searched column,  the real column name in the CSV file is LenA2. Please try change the column name accordingly. By the way, I saw you enter 0' for default value, please also change it to 0 mm.
    Please also make sure the file "M_Generic 1 Mpa Slip Flange.csv"  is copied to Lookup table folder. The look up table folder could be found in Revit.ini file, by the following clause:
    LookupTableLocation=<lookup table file path>
    On my computer, the clause is LookupTableLocation=C:\ProgramData\Autodesk\RME 2011\LookupTables, so my lookup table files are located in C:\ProgramData\Autodesk\RME 2011\LookupTables.
    ______________________________________________________________
    If my post answers your question, please click the "Accept as Solution" button. This helps everyone find answers more quickly!
    黄庆九
    Qingjiu Huang
    Support Specialist
    Product Support
    Autodesk, Inc.
