• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Revit MEP
    Active Member
    Fixture Units not calculating
    172 Views, 1 Replies
    09-27-2012 06:02 AM
    I created a plumbing fixture family with a shared parameter (ie, HWFU).  When I set the connector to an Instance parameter, the fixture units calculate just fine.
    I set the connector to a Type parameter, load the family into the project (overwrite existing & parameter values), change the Type parameter to a  number (1 in this case), the calculated fixture units in the pipe drop to 0.
    Any ideas on why this isn't working?  I'm using Revit MEP 2013.
    Please use plain text.
    Active Member
    Re: Fixture Units not calculating
    09-27-2012 06:09 AM in reply to: DrewH09
    I just noticed that whatever I set the "default" value to before I load it into the project is what's calculated.  Whenever I change the parameter, whether it be in the schedule or by Edit Type, it does not reflect in the pipe system.
