Autodesk Revit MEP
- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Float this Topic to the Top
- Bookmark
- Subscribe
- Printer Friendly Page
Fitting Angle
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
So I have a bunch of fittings that I am trying to schedule, but do to the nature of revit, and sloped pipes a lot of my fittings are coming in as 89.64 derees and things like that. I want to group all the 90 degree fittings together but I cant because the angles are not the same. When I open up the family and create a parameter to roundup the angle ie: Roundup(Angle) it says "inconsistent units". How is this possible? The only units in there are the Angle units, the rest is just a function. If you know how to side step this annoyance please let me know. Thanks!
Re: Fitting Angle
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
That's a nice little bug you found, it seems - the Angle type parameter is not subjectable to the ROUND function! So as a workaround, use:
roundup(Angle / 1°) * 1° (copy/paste this or you can just type it without the ° sign and Revit will fill that part in automatically)
⁞|⁞ Please use the
Re: Fitting Angle
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
And as an additional thought - you might be able to get away with a Calculated Value in your schedules rather than going through all of your Families and modifying the formula. It would use the exact same formula, except it would reference your Shared Parameter instead. Just ask if you need more info.
⁞|⁞ Please use the
