Autodesk Revit MEP
- Mark Topic as New
- Mark Topic as Read
- Float this Topic to the Top
- Printer Friendly Page
Re: Fatal error loading family
- Highlight
- Email to a Friend
- Highlight
- Email to a Friend
Thank you for the journal file.
The first thing I see is that Update 2 is not installed. I would download and install Update 2 from the page below:
Revit MEP: http://usa.autodesk.com/adsk/servlet/item?siteID=1
Having said that, the issue is that the type definition of a shared parameter "Phase" does not match between the project file and family. I would verify the type definitions are the same.
- Highlight
- Email to a Friend
- Highlight
- Email to a Friend
That does look like the parameter Revit is having the issue with.
- Highlight
- Email to a Friend
I am having a similar if not identical issue. Did you figure out a way to resolve this?
-J
- Highlight
- Email to a Friend
To confirm if this is the same issue, please upload a journal from the session where you are seeing the behavior.
- Highlight
- Email to a Friend
Here you are sir. Hope this helps.
- Highlight
- Email to a Friend
Thank you for the update.
From the journal file, it does look to be the same issue. You'll need to delete the shared parameter from the family, and recreate it both the family and project file.
Having said that, if you are on Subscription, we may have additonal options.
- Highlight
- Email to a Friend
I have tried to delete the parameter from the family, but I still get the same outcome when I try to load it. According to the journal file, it is still hanging up on the "phase" parameter even though I deleted it. Is there a way to remove a shared parameter from a family other than from the "family types" dialogue?
- Highlight
- Email to a Friend
I believe I am having the same issue with a mismatched shared parameter "phase". I have attached my journal file, has there been a resolution to this? I've tried to remove all the parameters, but still seem to have the problem.
I also have a subscription, you mentioned there may be other options?
