• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Revit MEP
    Re: Fatal error loading family
    07-23-2012 08:36 AM in reply to: Chris.Aquino
    Please use plain text.
    Product Support
    Chris.Aquino
    07-23-2012 12:53 PM in reply to: rschnureIV
    Thank you for the journal file.
    The first thing I see is that Update 2 is not installed. I would download and install Update 2 from the page below:
    Revit MEP: http://usa.autodesk.com/adsk/servlet/item?siteID=123112&id=14973660
    Having said that, the issue is that the type definition of a shared parameter "Phase" does not match between the project file and family. I would verify the type definitions are the same.
    Chris Aquino
    Revit Support Specialist
    The Revit Clinic
    @Revitclinic
    07-24-2012 10:05 AM in reply to: Chris.Aquino
    By phase do you mean, and electrical phase? Robert Schnure Mechanical Designer/Cad Coordinator Mechanical Engineering Tel.: (610) 524-5920 x 2251 Dir.: (610) 423-6251 Toll free: (877) 243-9711 Fax: (610) 524-2443 SNC-Lavalin Project Services, Inc. 436 Creamery Way, Suite 100 Exton | Pennsylvania | United States | 19341NOTICE - This email message, and any attachments, may contain information or material that is confidential, privileged and/or subject to copyright or other rights. Any unauthorized viewing, disclosure, retransmission, dissemination or other use of or reliance on this message, or anything contained therein, is strictly prohibited and may be unlawful. If you believe you may have received this message in error, kindly inform the sender by return email and delete this message from your system. Thank you.
    Product Support
    Chris.Aquino
    07-24-2012 10:48 AM in reply to: rschnureIV
    That does look like the parameter Revit is having the issue with.
    Chris Aquino
    The Revit Clinic
    @Revitclinic
    Active Member
    08-08-2012 05:33 PM in reply to: rschnureIV
    I am having a similar if not identical issue.  Did you figure out a way to resolve this?
    -J
    Product Support
    Chris.Aquino
    08-09-2012 11:03 AM in reply to: Revit_J
    To confirm if this is the same issue, please upload a journal from the session where you are seeing the behavior.
    Chris Aquino
    The Revit Clinic
    @Revitclinic
    Active Member
    08-09-2012 12:18 PM in reply to: Chris.Aquino
    Here you are sir.  Hope this helps.
    Product Support
    Chris.Aquino
    08-09-2012 02:08 PM in reply to: Revit_J
    Thank you for the update.
    From the journal file, it does look to be the same issue. You'll need to delete the shared parameter from the family, and recreate it both the family and project file.
    Having said that, if you are on Subscription, we may have additonal options.
    Chris Aquino
    The Revit Clinic
    @Revitclinic
    Active Member
    08-09-2012 02:37 PM in reply to: Chris.Aquino
    I have tried to delete the parameter from the family, but I still get the same outcome when I try to load it.  According to the journal file, it is still hanging up on the "phase" parameter even though I deleted it.  Is there a way to remove a shared parameter from a family other than from the "family types" dialogue?
    New Member
    09-07-2012 09:12 AM in reply to: Chris.Aquino
    I believe I am having the same issue with a mismatched shared parameter "phase".  I have attached my journal file, has there been a resolution to this?  I've tried to remove all the parameters, but still seem to have the problem.
    I also have a subscription, you mentioned there may be other options?
