• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Revit MEP
    Fatal error loading family
    587 Views, 20 Replies
    07-18-2012 08:10 AM
    I am getting fatal errors when I try to load certain families into my revit mep 2012 projects.  Any Ideas?
    Please use plain text.
    Re: Fatal error loading family
    07-18-2012 08:12 AM in reply to: rschnureIV
    Can you provide a little more info - perhaps an image of the error message?
    Corey D.        LogoEE.png   AutoCAD user  Revit user
    ⁞|⁞ Please use the Mark Solutions!.Accept as Solution and Give Kudos!Give Kudos functions as appropriate to further enhance the value of these forums. Thank you! ───────────────────────────────────────────────────────────────────────────────────────────
    07-18-2012 08:18 AM in reply to: CADastrophe
    I attached a pic of the error.  Trane seems to think it has something to do with shared parameter files?  Does this sound familiar?
    07-18-2012 08:33 AM in reply to: rschnureIV
    I was hoping there'd be some actual, useful information in that message...
    Well, in order to determine if it is in fact a problem with Shared Parameters, you can perform this test:
    Open the family, and remove ALL parameters that you can, and then load it into a blank project. Does it still crash?
    If not, can you post the family file so we can take a gander?
    07-18-2012 08:44 AM in reply to: CADastrophe
    I can load this family into a blank project with no errors
    07-18-2012 09:03 AM in reply to: rschnureIV
    Now try loading it into the project that crashed.
    07-18-2012 09:06 AM in reply to: CADastrophe
    There is no attachment
    07-18-2012 09:14 AM in reply to: rschnureIV
    Sorry, I meant loading yours with the removed parameters. It if doesn't crash, then the troublesome parameter can be isolated.
    07-18-2012 09:20 AM in reply to: CADastrophe
    I removed all the parameters I could and it still crahsed when I inserted it.
    Product Support
    Chris.Aquino
    07-23-2012 08:26 AM in reply to: rschnureIV
    After a search of our Customer Error Report database, I don't see any from your email address. Can you please post a journal from a session where you saw the crash?
    They should be in the location below:
    C:\Users\%username%\AppData\Local\Autodesk\Revit\Autodesk Revit MEP 2012\Journals
    Chris Aquino
    Revit Support Specialist
    The Revit Clinic
    @Revitclinic
