• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Revit MEP
    FLOOR PLANS
    108 Views, 2 Replies
    12-01-2011 12:20 PM
    How do I create a viewport from a floor plan
    Please use plain text.
    Valued Mentor
    dennis
    Re: FLOOR PLANS
    12-01-2011 12:23 PM in reply to: miguel202
    Are you wanting to get the FloorPlan view onto a Sheet?  If so, open the Sheet view, then in the Project Browser, pick and hold on the FloorPlan view name, drag and drop on the Sheet view.  If that isn't what you are after, then please give a bit more detail.
    Re: FLOOR PLANS
    12-01-2011 12:26 PM in reply to: miguel202
    The "viewport" boundaries are controlled by the Crop Region. Under the View's properties, you can turn it on and adjust it as necessary.
    Corey D.        LogoEE.png   AutoCAD user  Revit user
    ⁞|⁞ Please use the Mark Solutions!.Accept as Solution and Give Kudos!Give Kudos functions as appropriate to further enhance the value of these forums. Thank you! ───────────────────────────────────────────────────────────────────────────────────────────
