• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Revit MEP
    Board Manager
    Re: FABmep for Revit MEP available on Autodesk Labs
    07-09-2012 08:07 AM in reply to: BrianWelch3883
    @BrianWelch
    I gathered some information from Steve and wrote a blog posting for you.
    http://labs.blogs.com/its_alive_in_the_lab/2012/07/fabmep-import-for-revit-mep-now-available-on-auto...
    Scott Sheppard
    Program Manager
    Autodesk Labs
    Please use plain text.
    Re: FABmep Import for Revit MEP available on Autodesk Labs
    07-09-2012 09:17 AM in reply to: bparrell
    Figured it out.For those that are interested.They have change the ext on the mapping file.Change from .Bix to .Map and all will be good.
    Board Manager
    07-10-2012 11:10 AM in reply to: bparrell
    Based on the inquiries in this forum, I sketched out the workflow.
    http://labs.blogs.com/its_alive_in_the_lab/2012/07/fabmep-import-for-revit-mep-a-picture-is-worth-10...
    Thanks for providing the impetus.
    Scott Sheppard
    Program Manager
    Autodesk Labs
    Active Member
    NelsonStark
    07-12-2012 09:56 AM in reply to: BrianWelch3883
    "exportrun" is the command without the quotes. or "erun" or use icon in FABmep if not there right click in FABmep screen go to tools then click DATA Exchange this will bring the icon up
    New Member
    07-12-2012 11:07 AM in reply to: NelsonStark
    I am running 2.41.157, i did click on data exchange and do not see the icon, i have importrun but no exportrun.
    Any suggestions
    Active Member
    NelsonStark
    07-12-2012 11:28 AM in reply to: scott.sheppard
    That is the same thing I am running. Now do you have the import icon? Also do you have Fabrication FABmep & Revit installed and if so is the addin's showing up to import and export from Revit? This might be an install problem. Did you download the Autodesk Lab add-on?
    New Member
    07-12-2012 11:56 AM in reply to: NelsonStark
    In FAB i have the import icon but not the export icon.
    I downloaded the FABtoRME.zip Revit add-in from Autodesk labs, i installed it and have the FAB to RME add-in.
    I have not yet installed Revit convert 2013, i have it for Revit 2012 but not Revit 2013, where can i get that?
    Active Member
    NelsonStark
    07-12-2012 12:12 PM in reply to: scott.sheppard
    Try this site I think it was a problem I had after using this everything is working. http://usa.autodesk.com/adsk/servlet/ps/dl/item?siteID=123112&id=19399552&linkID=9243099
    07-13-2012 11:33 AM in reply to: NelsonStark
    I was looking for a place to post this,but we are in dire need of a multiline editor when mapping systems(Revit) to fabrication.Should be able to sort all supply and map.Please
    New Member
    sthompson069
    Import CAD MEch Services into FABMep
    08-10-2012 07:22 AM in reply to: scott.sheppard
    When I go to import services, nothing happens. Any suggestions?
