• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Revit MEP
    Distinguished Contributor
    Export to DWF: set default to DWF not DWFx
    351 Views, 4 Replies
    07-13-2010 06:24 AM
    Is there a way to set my default DWF format to DWF instead of DWFx?  My plotter does not currently recognize the DWFx as a valid format, probably because of some issue I have not had time to look into.
    Mitch
    Please use plain text.
    jd
    New Member
    jd
    Re: Export to DWF: set default to DWF not DWFx
    11-07-2011 04:58 AM in reply to: mmermel
    Did you find a solution? We have searches for a way to change the default as well.
    Jens
    Active Contributor
    01-04-2012 09:44 AM in reply to: jd
    when asked to save your DWF/DWFx file, use the drop down to select what type you would like to use.  Hope it helps
    01-04-2012 10:37 AM in reply to: mmermel
    Sorry, but that does not help.  I already know about that.  The problem is that no matter how much you educate people about the setting they must use, they forget about it.  That means that if I never want anyone to accidentally plot to a DWFx, I need a way to set DWF as a default.
    M
    01-04-2012 11:09 AM in reply to: mmermel
    We have that issue too, with Worksets and DWFs. My solution was to make each user wear a reminder WWJD bracelet. (We Want Just .DWFs!). But there may be converters out there that might be faster than re-plotting.
    Corey D.        LogoEE.png   AutoCAD user  Revit user
    ⁞|⁞ Please use the Mark Solutions!.Accept as Solution and Give Kudos!Give Kudos functions as appropriate to further enhance the value of these forums. Thank you! ───────────────────────────────────────────────────────────────────────────────────────────
