• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Revit MEP
    Valued Contributor
    Exploding Imported Cad
    247 Views, 1 Replies
    09-14-2012 11:00 AM
    Previously I've been able to explode imported cad items.  Now when I try to explode some cad dwg's I've been getting a message.  Attached is the message below.  I was able to do the AECTOACAD-command on some of the dwgs and it exploded fine, doesn't seem to be working now.  Any ideas?
    Please use plain text.
    Valued Mentor
    julianjameson8403
    Re: Exploding Imported Cad
    09-17-2012 02:47 AM in reply to: Richie535
    It's diffcult to tell without seeing the AutoCAD content you are exploding.
    Just a thought - why do you want to import and explode AutoCAD based objects? That's one way to quickly kill your model. Can you not live with CAD into families and then replicate using native Revit elements?
    If my reply answers your query, please use the Accept as Solution.
    Please give Kudos as appropriate to enhance the value of these forums.
    Thank you!
