• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Revit MEP
    Active Member
    Existing pipe showing as new`
    153 Views, 1 Replies
    10-22-2012 07:11 AM
    I have an existing pipe drawn on my demolition plan on it's own filter and color that shows up correct but when I go to my new floor plan and turn on that filter my existing pipe shows up as new, i alos have new sanitary on the plan and when I turn off the filter it turns off the existing sanitary as well. Under phasing on the new plan, it's phase created is existing. Any ideas how to change or fix?
    Please use plain text.
    Re: Existing pipe showing as new`
    10-23-2012 10:07 AM in reply to: rjones
    In your new floor plan, what is the Phase and Phase Filter set to?
    Corey D.        LogoEE.png   AutoCAD user  Revit user
    ⁞|⁞ Please use the Mark Solutions!.Accept as Solution and Give Kudos!Give Kudos functions as appropriate to further enhance the value of these forums. Thank you! ───────────────────────────────────────────────────────────────────────────────────────────
