• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Revit MEP
    crigoli
    Re: Electrical Family Constraint issue effecting elevation
    05-13-2011 04:41 AM in reply to: RedMan77
    That sounds about right.  There also seems to be a glitch in the programming when you switch between devices and changing the hosting option from Vertical Surface, Face, Work Plane hosted.  I've had this happen where devices have been placed correctly, then switched to a ceiling mounted device and changed it to Face hosted to place onto the ceiling then changed back to the receptacle to vertical surface hosting and it wouldn't show correctly - OR it would show correctly but the elevation would show 0'-0" even though it was at 4'-0".  Just another item to be wary about until it's fixed.
    -crigoli
    Please use plain text.
