• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Revit MEP
    norcaljess
    Electrical Component Labels
    209 Views, 3 Replies
    10-18-2012 02:17 PM
    How do I change the orientation or move the label that is inserted with the electrical components?  For instance, if I insert a GFCI duplex receptacle, how do I move the "GFCI" label, (the one that automatically comes in with the family)?
    Jess
    Please use plain text.
    Valued Mentor
    julianjameson8403
    Re: Electrical Component Labels
    10-19-2012 02:46 AM in reply to: norcaljess
    Generally you don't when using the OOTB families. You can start messing about adding ref planes and dims to make it more flexible.
    Or the simpleton way (me for example) of dealing with it is to remove the label from the family then make a tag that picks up the parameter value in the model.
    Some would say that this will create an additional coordination risk as there now becomes a manual check that you have tagged the GFCI families. However the panel schedules can be adjusted to automatically display the fault parameter values
    If you look on here you may find a method for dealing with this otherwise check out the "Revit @ Waterman" blog where he covered someting similar
    If my reply answers your query, please use the Accept as Solution.
    Please give Kudos as appropriate to enhance the value of these forums.
    Thank you!
    Member
    hluu007
    10-26-2012 10:30 AM in reply to: norcaljess
    Here your answer: Manual input.
    Sorry, I don't speak or write well. Can explain you too much.
    Henry
    Edited by
    Discussion_Admin
    norcaljess
    10-26-2012 01:40 PM in reply to: hluu007
    If I wanted to use manual input, I would have done that.
