• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Revit MEP
    norcaljess
    Dumb View Title Question
    151 Views, 1 Replies
    08-02-2012 03:10 PM
    I can't believe I can't figure this out... See attached example.  How do I edit the text on this view title so that it doesn't wrap around & just continues on one line?  I can't even figure out how to open the family to edit it, since the "Edit Family" button doesn't come up when you click on it.
    Thanks!
    Jess
    Please use plain text.
    Valued Mentor
    julianjameson8403
    Re: Dumb View Title Question
    08-02-2012 05:12 PM in reply to: norcaljess
    Depending on how your company has set up the view titles will affect which view title annotation symbol you want to change.
    Sselect the view title and check its type properties. The view title annotation symbol should be listed there. Then go fin it in the family section of the project browser. When you find it right click on the family and select edit so you can stretch the label in the family editor. Remember not to expand the family to show the types as you can't access the family editor through those.
    If my reply answers your query, please use the Accept as Solution.
    Please give Kudos as appropriate to enhance the value of these forums.
    Thank you!
