• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Revit MEP
    Valued Contributor
    Duct tagging
    157 Views, 6 Replies
    10-24-2012 03:23 PM
    Is there a way to tag all my ducts and pipes in a certain view at once? Like with a single command? I have the proper tags loaded, is there a way to associat a certain tag as a default tag then simply have revit tag everything from a few select categories at one time? Or do I have to tage everything manually? Thanks,
    Please use plain text.
    Valued Contributor
    Sandleaz
    Re: Duct tagging
    10-24-2012 04:26 PM in reply to: michaelmead
    In revit mep 2012, i believe there is a tag all button under the annotate tab.  Not sure whether it understands the difference between round and rectangular ducts + whether or not you have one tag that allows for both.  Also remember that revit might place the tag in a bad location.  I usually just type TG and tag stuff manually, it's fairly simple.
    Valued Contributor
    Re: Duct tagging
    10-24-2012 05:12 PM in reply to: Sandleaz
    Yeah the tag all button is just that, it tags everything that does not discriminate. I want to tag two things, not all of my VAV boxes and whatnot, not air terminals and the whole 9 yards. I just want to tag a couple things. Any ideas?
    Active Contributor
    Re: Duct tagging
    10-24-2012 07:04 PM in reply to: michaelmead
    Yes there is a tag All option under Annotate Tab.  It is extremely indiscriminate and will tag ALL objects with the selected tag within that category for a particular open view.  At times it can cause more problems as there is no control on location it just tags everything but it does certainly have its use.
    Active Contributor
    Re: Duct tagging
    10-24-2012 07:08 PM in reply to: michaelmead
    You can use it to place the grille tags on all grilles only you just need to select that Category and tag and Apply.
    Alternatively there is an option to Apply only to selected objects in which you could select everything in a plantroom and all all Mark Numbers to Mechanical Equipement.
    Valued Contributor
    Re: Duct tagging
    10-25-2012 07:05 AM in reply to: michaelmead
    Hey, yeah i figured it was probably this easy, but mine doesnt work like that. Ive attached a picture of the Tag All menu that I am getting, which is confusing because it wont let me select, or unselect anything in there. Double clicking, right clicking, nothing works. Any suggestions?
    Re: Duct tagging
    10-25-2012 07:15 AM in reply to: michaelmead
    michaelmead wrote:
    "...it wont let me select, or unselect anything in there. Double clicking, right clicking, nothing works. Any suggestions?"
    Select the elements prior to activating the 'Tag All' command.
    Corey D.        LogoEE.png   AutoCAD user  Revit user
    ⁞|⁞ Please use the Mark Solutions!.Accept as Solution and Give Kudos!Give Kudos functions as appropriate to further enhance the value of these forums. Thank you! ───────────────────────────────────────────────────────────────────────────────────────────
