• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Revit MEP
    Distinguished Contributor
    Duct elbow increments revisited
    280 Views, 2 Replies
    12-21-2012 11:01 AM
    Ive seen the earlier post from 2008 and I'm wondering if there is still no way 'predetermine' what elbow angles ducts will use connecting between different elevations. This is done all the time. Is there somewhere to 'force' only 45^ elbows or 30^ elbows?
    Striving to be a WOMBAT, Waste Of Money, Brains, & Talent...
    ⁞|⁞ Please use the Mark Solutions!.Accept as Solution and Give Kudos!Give Kudos functions as appropriate to further enhance the value of these forums. Thank you!
    Please use plain text.
    Product Support
    Chris.Aquino
    Re: Duct elbow increments revisited
    01-07-2013 01:08 PM in reply to: dtiemeyer
    In 2013, under Manage > Settings > Mechanical Settings > Pipe Settings (or Duct Settings) > Conversion, you can set the Elbow Increment Angle.
    Chris Aquino
    Revit Support Specialist
    The Revit Clinic
    @Revitclinic
    01-07-2013 02:09 PM in reply to: Chris.Aquino
    Thank you for the response Chris. This appears to apply only to the Generate Layout tool, is there a way to control the 'automatically connected' duct when simply using the 'Duct' command?
    For example, I have one duct at 10' and another at 12', and i know I want to have 2 45s and a sloping section of duct?
    Dustin
