• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Revit MEP
    Active Member
    Duct Creation Problem In offset Revit 2013
    316 Views, 3 Replies
    01-03-2013 01:35 AM
    Dear,
    I have a problem with revit Duct drawing through programme in C#.
    Explanation: I draw a duct 24''*12'' with offset 0.0 to 50'' then i change offset 0.0 to 9.0 and then draw to 50'' and again i change offset to 0.0 . After that Drawn duct shows the size 24''*12'' but appearnce is not proper you can see in image. Please help me  if anyone has solution.
    Please use plain text.
    nitinjambhale
    Re: Duct Creation Problem In offset Revit 2013
    01-03-2013 01:47 AM in reply to: manishsingh12jan
    i think the problem is of Width, depth setting. Please check at once.
    Member
    Hi All,
    The question which asked my Manish, is good one, i am wondering for this answer.
    Please reply any one, if you people already done.
    Thankyou,
    Mallikarjuna
    Active Member
    01-03-2013 01:48 AM in reply to: nitinjambhale
    I set Hight and width correct. But looks same  as image above.
