• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Revit MEP
    Active Member
    Double Lined Piping
    202 Views, 8 Replies
    09-11-2012 07:45 AM
    I am working on a plumbing design and am having touble with the settings. I am working on my sanitary lines and in plan view they are showing up as double lined piping regaurdless of diameter. The plan view is set to coarse and wireframe, and as far as I know, there are no filters besides colour that is applied to the piping. Also, it doesn't matter what line type I am using, I am still having the same issue. I need these pipe lines to show up as single line.
    Any help would be appreciated.
    Please use plain text.
    *Expert Elite*
    Re: Double Lined Piping
    09-11-2012 07:54 AM in reply to: Niamhy14
    Niamhy14 wrote:
    "...they are showing up as double lined piping regaurdless of diameter..."
    Does this also indicate that the width of the double lines does not change according to the pipe size?
    What is most likely the case is that the Pipe Category is overridden to "Detail Level: Fine", which means that it will show as such regardless of the View's setting. You can check this by going to Visibility/Graphics Overrides and looking at the "Detail Level" column for the piping Categories.
    Corey D.        LogoEE.png   AutoCAD user  Revit user
    ⁞|⁞ Please use the Mark Solutions!.Accept as Solution and Give Kudos!Give Kudos functions as appropriate to further enhance the value of these forums. Thank you! ───────────────────────────────────────────────────────────────────────────────────────────
    Active Member
    09-11-2012 09:12 AM in reply to: CADastrophe
    The width of the double lined pipes do change along with the diameter.
    I did check the Visibility/Graphics Overrides to see what the detail level was for piping, and they are all set to "By View." I tried to change it but it doesn't seem to make any difference.
    *Expert Elite*
    09-11-2012 09:17 AM in reply to: Niamhy14
    Are the fitting appearing double-line as well? If so, could you post an image?
    Active Member
    09-11-2012 09:25 AM in reply to: CADastrophe
    No they aren't. This is how the piping looks:
    *Expert Elite*
    09-11-2012 09:42 AM in reply to: Niamhy14
    I don't know of any other possible causes beside the V/G override. I guess if the pipe were insulated, and the Pipe Insulation Category was being forced to Fine in V/G, that would cause this, too. What version of Revit are you using?
    Active Member
    09-11-2012 09:58 AM in reply to: CADastrophe
    All of the piping settings are to By View.
    I am using Revit MEP 2012.
    *Expert Elite*
    09-11-2012 12:00 PM in reply to: Niamhy14
    Is this occurring consistently or only on that View? Is it just that Pipe System (Sanitary) or all of the piping?
    Active Member
    09-12-2012 06:05 AM in reply to: CADastrophe
    Wow am I ever dumb. It turns out that it was my view range that was affecting the pipe. I noticed this when I went to a level below and the piping I was trying to change to single line was single line on that view. I checked the view range and adjusted and it worked.
    Thanks for your help. I did learn a lot over this forum that I didn't know so it wasn't a complete waste. Thanks again. I really appreciate it.
