• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Revit MEP
    Distinguished Contributor
    thombrady
    Disappearing Ribbon
    277 Views, 3 Replies
    02-06-2013 02:49 PM
    Does anyone know why every once in a while my ribbon disappears & I cannot change commands? This only happens once in a while & when I restart it is fine. Does REVIT get tired & need a rest....
    Please use plain text.
    Distinguished Mentor
    Re: Disappearing Ribbon
    02-07-2013 02:32 PM in reply to: thombrady
    I've never heard of that particular issue.
    I have had a user lose some of is tools in the ribbon, but not all.
    Do you have the latest updates?
    if so, I would suggest a repair on the installation.
    “Anything worth doing is worth doing poorly, until you can learn to do it well.”
    thombrady
    02-08-2013 04:56 AM in reply to: thombrady
    Thank you for responding. No we do not have any updates but I will have my Tech guy get them.
    New Member
    noughan
    02-16-2013 01:40 AM in reply to: thombrady
    Are you using dual or multiple screens ?
    If yes, you can try to change the resolution of both screen and reverse it (1 to 2 and 2 to 1) and check if that behavior is still happening. You can also unplug on screen and let only one to see.
    You can also check the version of your Microsoft .NET Framework components. You shoud have the "4 Client Profile" and the "4 Extended" installed on your machine.
    Thank you in advance for your feedback.
    Best regards,
    Nabil Nougha
    Support Specialist
    Product Support
