• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Revit MEP
    Active Member
    Custom Tags
    181 Views, 1 Replies
    07-21-2006 09:42 AM
    Is there a way to tag equipment placed in a model with information from the family and information from the model. For example, I insert a panel board into the model and want a label that includes volts/sector/instance#/floor/use/building? I was thinking this could be accomplished with custom parameters, but am not sure. I was thinking of setting up custom parameters in the model for sector, floor and building and then combine these parameters with family parameters volts and use. Am I on the right track. Any help is much appreciated.
    Thank You........Aaron
    Please use plain text.
    Employee
    Re: Custom Tags
    08-01-2006 04:34 AM in reply to: aaron1
    Have you investigated what Label properties are available, i.e., start with the Panel Name Annotation, edit the family to add more labels, and modify the labels' properties to show different information.
    I think your thought method is correct, but in only spending a couple of minutes with it, I ran into the following:
    With a panel:
    You can label its voltage
    I'm not sure what Sector means
    For Instance #, you may use Mark
    Floor/Use/Building - These aren't native family properties, and as such, I am not sure if you could label components with such information.
    FWIW,
    MS
    Martin Schmid, P.E.
    Product Manager - Analysis and Countrification
    Architecture, Engineering, and Construction
    Autodesk, Inc.
