Autodesk Revit MEP
Topic Options
- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Float this Topic to the Top
- Bookmark
- Subscribe
- Printer Friendly Page
Create Tags for No catagory
Options
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
175 Views, 2 Replies
07-21-2011 06:43 AM
Hi!
I would like to create a plumbing riser tag. I am not sure what catagory to use or what type of tag I should use.
Any suggestions are welcome.
Thanks ![]()
Re: Create Tags for No catagory
Options
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
07-21-2011 07:36 AM in reply to:
sforsberg215
What version of Revit are you using?
Corey D.
⁞|⁞ Please use the
.Accept as Solution and
Give Kudos functions as appropriate to further enhance the value of these forums. Thank you! ───────────────────────────────────────────────────────────────────────────────────────────
⁞|⁞ Please use the
Re: Create Tags for No category
Options
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
07-21-2011 09:53 AM in reply to:
sforsberg215
sforsberg215 wrote:Hi!
I would like to create a plumbing riser tag. I am not sure what category to use or what type of tag I should use.
It depends on the category your going to tag. EVERYTHING is based off a category. If your going to tag a pipe riser, than you would use pipe tag. If you have a cap on the top you would use pipe accessory/fitting tag depending on what the family/system family is categorized under..Etc.
“Anything worth doing is worth doing poorly, until you can learn to do it well.”
