• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Revit MEP
    Active Member
    Accepted Solution
    Copy/Monitor - Type Mapping Tracking flows
    156 Views, 2 Replies
    09-26-2012 10:45 AM
    Working on a project where another firm is modeling the fan coil units and we're hooking up the piping.  I was hoping I'd be able to copy/monitor each piece using the "type mapping" behavior.  However, it doesn’t seem to pick up on a change of flow (i.e. 5 GPM to 10 GPM) using the coordination review.
    Am I too hopeful?
    Thanks in advance.
    Please use plain text.
    *Expert Elite*
    Re: Copy/Monitor - Type Mapping Tracking flows
    09-26-2012 10:55 AM in reply to: dworakma
    I believe that you are, unfortunately. Copy/Monitor simply creates a copy of the element and creates an association, but does not convey any of the design information from the linked project. Some of the Parameter Values will be translated when the Copy/Monitor first occurs, but if changed in the Linked Project, it won't translate those updated values on to your elements.
    You can Tag the elements through the Linked Project or Schedule them to get a current reading on their values to compare to yours.
    Corey D.        LogoEE.png   AutoCAD user  Revit user
    ⁞|⁞ Please use the Mark Solutions!.Accept as Solution and Give Kudos!Give Kudos functions as appropriate to further enhance the value of these forums. Thank you! ───────────────────────────────────────────────────────────────────────────────────────────
    Valued Mentor
    julianjameson8403
    09-26-2012 12:39 PM in reply to: dworakma
    Try a Mechanical Equipment Schedule showing your equipmennt and the equipment in the linked model shown with relevant parameters displayed
    If my reply answers your query, please use the Accept as Solution.
    Please give Kudos as appropriate to enhance the value of these forums.
    Thank you!
