• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Revit MEP
    New Member
    Connecting to Revit Central Server 2012
    194 Views, 2 Replies
    05-15-2012 07:13 AM
    Is it possible for user at the main corporate offices to connect to the central server running in that office? We are being told that we must have a local server running that the users connect to but the installation indicates users can connect to the central server.
    Please use plain text.
    Product Support
    fernanda.firman
    Re: Connecting to Revit Central Server 2012
    05-29-2012 05:00 PM in reply to: donphillips
    You are rigth, if you are all working from the same office you don't need to set up the local servers. The Central Server can function as "local server" (in this case).
    Fernanda Lima Firman
    Revit Support Specialist
    Autodesk, Inc.
    Revit Clinic
    If this helped solve your issue - remember to 'accept as solution' to help others find answers.
    Member
    12-16-2012 12:51 AM in reply to: fernanda.firman
    Hello Fer
    We have installed AutoDesk Revit Server 2013 in Central Server(Windows 2008 R2 Standard) and the  Local Server (Windows 2008 R2 Standard) .
    How to configure Central Server and Local Server for use with multiple offices over a WAN?
    Please infom me Which is the Environment Varible value of following 3
    1.Central Server
    2.Local Server
    3.Host
    I know that environment variable is RSROLE2013 . Which is the value ? Is it Host,Accelerator,Admin for Central Server Environment Varible value.
    Our issue is revit model not synchronizing  from Local to  Central Server.
    Its only Synchronizing from Host to Local Server.
    How do we resolve this issue?
