Changing the Panel Schedule Default to Circuits Down
dennis
Advisor Advisor
dennis
I want to show the Panel Schedule as "Two Columns-Circuits Down", however, I can't seem to make Revit MEP 2011 give me the choice to apply the template.  It is listed when I select the Panel Configuration under Template Type:Branch Panel.  Any guesses on what it is I am missing?
eric_grey
Hi Dennis,
When creating a panel schedule for a panel, Revit checks the Panel Configuration parameter in the panel family and matches it to templates that use the same configuration.
HTH,
Eric
Eric Grey
Software QA Analyst
dennis
Ahhh, yes, finally found it.  You have to actually edit the family to see the parameter.  Thanks.
CarrieHoffman02
Thank you, Thank you, Thank you,!!!!
