• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Revit MEP
    Active Contributor
    DMaurer-Veca
    Central model doesn't allow synchronizing
    176 Views, 3 Replies
    10-10-2012 08:21 AM
    We have saved our model as a central file, but it will only allow one workstation to synchronise with the central. It seems whoever makes the file is the only one who can synchronize with the central model. Other workstations can create a local copy, edit it but cannot sync with the central model.
    Diane M
    Please use plain text.
    Re: Central model doesn't allow synchronizing
    10-10-2012 08:32 AM in reply to: DMaurer-Veca
    Did you enable worksets in the central file? Collaborate -> Worksets
    Valued Mentor
    dennis
    10-10-2012 08:33 AM in reply to: DMaurer-Veca
    Things to check:
    1) Check the Windows folder permissions as well as the Central file permissions itself.  Maybe it got saved with permissions set to read-only.  Check ownership, read-write settings, etc.
    2) Check how the folders are mapped.  If I am mapped to a folder as F: drive and you are mapped as G: drive, then that can cause issues.
    3) Does anyone have it opened directly?
    Active Contributor
    DMaurer-Veca
    10-10-2012 10:06 AM in reply to: dennis
    The problem seems to be specific to one workstation. So we are looking at an IT solution.
    Diane M
