• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Revit MEP
    Valued Mentor
    julianjameson8403
    Re: Can't Get Project Browser Back-PERIOD
    09-18-2012 09:23 AM in reply to: ghardy
    Once bound you can then "explode" the link and start working on it. There will undoubtedly be additional issues that this will cause - Copy/Monitored elements, unhosting of elements, etc.
    However it sounds like compared to the potential loss, these PITA issues will be less of a problem.
    Good Luck!
    If my reply answers your query, please use the Accept as Solution.
    Please give Kudos as appropriate to enhance the value of these forums.
    Thank you!
    Please use plain text.
    Active Member
    09-18-2012 09:41 AM in reply to: CADastrophe
    Yes I have tried the whole troubleshooting steps on 3 different machines.
    09-18-2012 09:44 AM in reply to: ghardy
    I figured as much.
    FYI - I posted this issue on AUGI for you before I read that you were a mod there!
    Corey D.        LogoEE.png   AutoCAD user  Revit user
    ⁞|⁞ Please use the Mark Solutions!.Accept as Solution and Give Kudos!Give Kudos functions as appropriate to further enhance the value of these forums. Thank you! ───────────────────────────────────────────────────────────────────────────────────────────
    Active Member
    09-18-2012 09:52 AM in reply to: CADastrophe
    Well thank you! i appreciate it, i already hooked you up with the Kudos. And if the Binding is the only way to get it done. Then I will do it. I will puit it as the accepted solution once it works and if it does not work. Then I will post it up here.
    Once again, Thanks for all your help guys.
    New Member
    11-20-2012 09:52 AM in reply to: ghardy
    I have this problem narrowed down to a specific file. (attached). No matter how I open this family, from inside the project, or by opening and auditing, I cannot get the project browser to appear. So far it has not affected any other families, or projects, but I live in fear. Attached are screenshots. The project broswer that does appear is from the project the family was opened from.
    Any ideas? At this point I have reset both the properties pallate, the project browser registry keys, reset the UIstate.dat file. and no changes. Other computers in our office have the same problem with the family, but not with other families in the project.
    I am using windows 7, latest build of REVIT 2013, wacom intous 5 tablet.
    New Member
    11-20-2012 09:56 AM in reply to: ghardy
    I did find a workaround that will work in a pinch, but is not a permanent solution.
    right-click on a piece in a 3-d view, then choos "find referring views" This will give you a list of available 2d views you can jump too.
    Still not a good solution...
