• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Revit MEP
    New Member
    Cable Tray Error
    282 Views, 1 Replies
    12-02-2012 05:03 PM
    I'm trying to run a few cable trays just to show where cables and the likes would come in inside a data center, and I've checked around YouTube and Google on how to make vertical sections (using offset). I've got no problem making horizontal segments, including turns and other fittings. When I go to set a different offset while drawing for a vertical segment, I get the following message:
    The routing solution failed because there is no default fitting type specified or the fitting cannot be found in the project. Ensure the fitting is loaded in the project and try again.
     I have the following settings:
    Using Cable Tray with Fittings - Ladder Cable Tray
    Automatically Connect is on
    Level: Level 1 (starting offset is 10', final is 3')
    Width: 12"
    Height: 4"
    Bend Radius: 4"
    Horizontal Justification: Center
    Vertical Justification: Middle
    Rung Space: 9"
    Thanks for your help!
    Please use plain text.
    Active Contributor
    Re: Cable Tray Error
    12-02-2012 06:47 PM in reply to: jkandres96
    You probably need to load the fittings and configure the cable tray routing options.
    Select the cable tray and Edit Type in the Propoerties The fittings options here need to be populated.
    Load the required families and apply the fittings to the routing options.
