• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Revit MEP
    Building type and Space Type
    297 Views, 4 Replies
    12-31-2012 01:39 AM
    does revit mep allow to us define a new space type and building type, Except for existings? and how can i create a new type?
    Murat AKAY
    Mechanical Draftsman
    Hvac-Fire-Plumbing-Piping
    Please use plain text.
    LisaDrago
    Re: Building type and Space Type
    12-31-2012 01:21 PM in reply to: akaymurat
    To my understandings - you cannot create new ones. Below is an image of the existing types available.
    LD
    If this helped solve your issue - remember to 'accept as solution' to help other find answers!
    You can't think AutoCAD and run Revit.
    Email: lisa@kalblue.com
    01-04-2013 02:36 AM in reply to: LisaDrago
    i checked that your sent image. for instance, if you want to design a medicine factory, how will you add a building type as the medicine factory and space type
    Thanks your answers
    Best Regards
    Murat AKAY
    Murat AKAY
    LisaDrago
    01-04-2013 05:10 AM in reply to: akaymurat
    Maybe I am not fully understanding you.
    The building type and space type parameters are used for calculating heating and cooling loads. You can adjust these settings from the default values - but over all this helps to set the parameters for the model and then down to spaces to create accurate analysis for load calculations.
    You cannot add to or remoeve the existing spaces.
    Not sure if this relaly helped...
    LD
    New Member
    01-05-2013 02:52 AM in reply to: akaymurat
    Hi all,
    Actually, the main problem is that,
    We are trying to define a space or building type, except already defined ones. The main question is, how can i define room conditions instead of existing? For example, i would like to set a room as a pharmaceutical laboratory, which needs very special conditions. Could you please tell how can we adjust and dedicate settings of the room?
    Thanks in advance,
