• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Revit MEP
    Distinguished Mentor
    asommer
    Accepted Solution
    Attached Duct not moving with Diffuser
    292 Views, 12 Replies
    09-17-2012 08:44 AM
    2013 MEP - I have diffusers hosted to a Reference Plane.  If I move the plane, the diffusers will move, but the duct detaches itself from the diffuser.  The flows seem to remain.  This did not happen in previous versions.
    Anyone else notice this?
    Please use plain text.
    Product Support
    alan.quinn
    Re: Attached Duct not moving with Diffuser
    09-19-2012 11:08 AM in reply to: asommer
    I tested and it seems to work for me. See the following video and file
    https://dl.dropbox.com/u/11938886/07639255_Video_1.mp4
    https://dl.dropbox.com/u/11938886/07639255_File.rvt
    If you are doing something different and its not working I will need to know your steps. Please create a video and post for review.
    Thanks for posting.
    Alan Quinn
    Support Specialist
    Product Support
    Autodesk, Inc.
    asommer
    09-21-2012 11:53 AM in reply to: asommer
    Try a Sidewall Diffuser (Vertical Face Hosted).
    asommer
    09-21-2012 01:18 PM in reply to: asommer
    Also, How do you create a video from your Revit?  This would be handy for training...
    Product Support
    alan.quinn
    09-24-2012 12:03 PM in reply to: asommer
    Same results in that it works. See the below and Jing (its free) is the tool I use for video's.
    https://dl.dropbox.com/u/11938886/07639255_File_1.rvt
    https://dl.dropbox.com/u/11938886/07639255_Video_2.mp4
    Thank you,
    Alan Quinn
    Support Specialist
    Product Support
    Autodesk, Inc.
    asommer
    09-25-2012 09:26 AM in reply to: asommer
    I will try the video soon.  I have an area of exposed duct, with exposed sidewall diffusers (No Wall).  I have to place the diffuser on a vertical Reference Plane, not perpendicular like you had it.  Revit will not connect a duct to a diffuser that is hosted to the duct's end.  I place the diffuser on the Vertial Reference Plane, then draw a duct from the diffuser's connector, tapping it into a main duct.  I then move the Reference Plane, noticing the diffuser moves, but the duct does not extend with the diffuser.
    In the sketch you sent, try moving the wall.  you might see the duct not moving with the diffuser.
    asommer
    09-25-2012 10:44 AM in reply to: asommer
    I Downloaded the Jing and created this... Please see Attached.
    asommer
    09-25-2012 11:07 AM in reply to: asommer
    Sorry, could not Attach SWF or a WMV.  How do you attach anything here?  How did you attach the mp4? It gives me a warning that it is not a supported extension.
    Product Support
    alan.quinn
    09-25-2012 04:02 PM in reply to: asommer
    You can only attach images. If you have a Dropbox account place the Revit file and video in it and send me the address. Thank you,
    Alan Quinn
    Support Specialist
    Product Support
    Autodesk, Inc.
    asommer
    09-25-2012 04:26 PM in reply to: asommer
    I cannot share my Revit file, but I can send you the wmv.  I think this works, I've never used this before.
    https://www.dropbox.com/sh/n7d1g3sdaslxett/h4drBDAJmQ
