• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Revit MEP
    norcaljess
    Accepted Solution
    Annotation Symbol in Electrical Family
    276 Views, 9 Replies
    02-11-2013 07:27 AM
    I'm attaching my electrical switch family that I have created.  The reason why I have nested the plate & fixture box families separate is because we need each instance to show up in a schedule.  My problem is that I can't get the $ switch symbol to show up on my plan when I insert the family.  I've tried looking at other switch families where the $ symbol shows up but I must be missing a step.  Anyone know what that is?
    Jess
    Please use plain text.
    *Expert Elite*
    Re: Annotation Symbol in Electrical Family
    02-11-2013 07:42 AM in reply to: norcaljess
    What template did you start with when you created this Family?
    Corey D.        LogoEE.png   AutoCAD user  Revit user
    ⁞|⁞ Please use the Mark Solutions!.Accept as Solution and Give Kudos!Give Kudos functions as appropriate to further enhance the value of these forums. Thank you! ───────────────────────────────────────────────────────────────────────────────────────────
    norcaljess
    02-11-2013 07:45 AM in reply to: CADastrophe
    :smileyfrustrated: I started with an Electrical Fixture template, the reason being, I have almost an identical family for Recepts that I created first, then used that to create this one.  Should I start over with another template?
    Jess
    norcaljess
    02-11-2013 07:48 AM in reply to: norcaljess
    And as far as the template I used to create the Recept family, I started with a 'Generic Model face based' because I want the Recept & Switch families to cut holes in the walls that host them.
    *Expert Elite*
    02-11-2013 07:53 AM in reply to: norcaljess
    No need to recreate, that should be OK. Open your Family and go to Family Category and Parameters. Check the option "Maintain Annotation Orientation" - that should fix it.
    norcaljess
    02-11-2013 07:56 AM in reply to: CADastrophe
    :smileymad:  AAAAAAAAARRRRRRRRGGGGGGGGGHHHHHHHHHH!!!!!!!!!!!!!!
    Thank you Corey!!!!
    *Expert Elite*
    02-11-2013 08:02 AM in reply to: norcaljess
    norcaljess wrote:
    ":smileymad:  AAAAAAAAARRRRRRRRGGGGGGGGGHHHHHHHHHH!!!!!!!!!!!!!!"
    Breathe...just breathe.  At least it was a simple answer this time, in lieu of the traditional 15-paragraph explanation/work-around!
    norcaljess
    02-11-2013 12:34 PM in reply to: CADastrophe
    That's what makes me so mad!  I am overthinking things because that's what I normally have to do with Revit, and it was a stinking check box!  And one that I had considered checking to see if it would fix my problem!  BUT I decided it just couldn't be that simple and let it go.  Revit... teaching me a lesson again!
    *Expert Elite*
    02-11-2013 12:48 PM in reply to: norcaljess
    Well, if it makes you feel any better, I really didn't think that would work, either...
    Oh, well. All you can do is laugh - 'cause if we're not laughing, we're crying. Or throwing our computer across them room...
    norcaljess
    02-11-2013 12:55 PM in reply to: CADastrophe
    Or... if you are one of the guys I work with... hurling verbal insults at Revit, as if it can understand you or has some personal vendetta against you.  :smileywink:
