• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Revit MEP
    Distinguished Contributor
    Accepted Solution
    Annotation Symbol Filled Region plots gray, not black
    243 Views, 2 Replies
    01-07-2013 12:21 PM
    Ive created a Duct Accessory (damper) containing an annotation symbol. In my project, this annotation symbols displays green (based on the fact my Duct System, supply air, is green). However when I print the edge line of the annotation symbol prints black, but the center prints green/gray (color/bw). Even changing the solid fill to 'color black' in the annotation family does not fix this problem.
    attached project is rmpe 2012.
    Thanks!
    Striving to be a WOMBAT, Waste Of Money, Brains, & Talent...
    ⁞|⁞ Please use the Mark Solutions!.Accept as Solution and Give Kudos!Give Kudos functions as appropriate to further enhance the value of these forums. Thank you!
    Please use plain text.
    *Expert Elite*
    Re: Annotation Symbol Filled Region plots gray, not black
    01-07-2013 12:37 PM in reply to: dtiemeyer
    We've encountered this issue as well - it seems that a solid hatch pattern will plot as its color regardless of the print setup. As a result, some of our "solid" hatch patterns are a series of actual lines, as per the image below.
    Corey D.        LogoEE.png   AutoCAD user  Revit user
    ⁞|⁞ Please use the Mark Solutions!.Accept as Solution and Give Kudos!Give Kudos functions as appropriate to further enhance the value of these forums. Thank you! ───────────────────────────────────────────────────────────────────────────────────────────
    01-07-2013 12:58 PM in reply to: CADastrophe
    Thanks CADastrophe,
    That's the route I've taken as well. I'm going to leave this open to see if anybody else, or perhaps Autodesk, cares to chime in. Cheer.
    Dustin
