Autodesk Revit MEP
- Mark Topic as New
- Mark Topic as Read
- Float this Topic to the Top
- Printer Friendly Page
ASHRAE TABLES inside revit!!! How can I use them?
- Highlight
- Email to a Friend
Hello!
How can I use ashrae tables in revit?
Where are they?
I n what can I Aplly them?
In ductwork for fittings pressure have told me about the ashare tables, how can I connect them into my schedullues?
I shall make ducts schedulles ir fittings schedulles?
Rui
Re: ASHRAE TABLES inside revit!!! How can I use them?
- Highlight
- Email to a Friend
The Ashrae tables are stored in this location
C:\Program Files\Autodesk\Revit MEP 2012\Program\ashrae.xml
They are applied to duct fittings through a parameter in the duct fitting family. You can schedule the pressure drop through a length of duct but not duct fittings or accessories. You cannot schedule the Ashrae fittings tables in a Revit schedule that I am aware of. If you want to check the Ashrae table applied to a fitting then you have to select thefitting and check its properties.
You can schedule the static pressure in a duct system.
Aside from the above information, I can't see what other help you need without speaking to Autodesk about why you can't schedule the Ashrae tables in Revit, etc.
Please give Kudos as appropriate to enhance the value of these forums.
Thank you!
- Highlight
- Email to a Friend
I have get the plug in ashrae viewer.
I think you would like to take a look.
Thanks a lot
Rui David
- Highlight
- Email to a Friend
Where is this plug-in available from?
Thank you!
- Highlight
- Email to a Friend
It is from Autodesk Labs. The app is called ASHRAE VIEWER.
- Highlight
- Email to a Friend
Couldn't see anything on their website for that. Does it depend on subscription or is has it moved?
Thank you!
- Highlight
- Email to a Friend
Hello!
take a look on this wevbsite:
http://bimboom.blogspot.com/2011/03/april-adn-plug
Best regards,
Rui
- Highlight
- Email to a Friend
Julian,
After you try the plug in can yiu give me the feed back about:
Is the air pressure calculated automatically for the entire duct ( includding al fittingsI with this plug in?;
or
Shall I visualize first the tables of plug in and input then pressure manually for each fitting?
Thanks rui
- Highlight
- Email to a Friend
Thanks for the link to the plug-in guys. Will look at it shortly.
Did try a search on the Labs website but no items were found - hence the further request for information.
Thank you!
- Highlight
- Email to a Friend
Hi everybody,
If I wanted to create a new coefficient table (TBL file) for use in a project, what software should I use to create the new TBL file ? Another question: is it normal for REVIT gives me a value of 0 for a loss of pressure for a fitting? So, I can not trust to REVIT for the results. An example: By an inspection of a small network of air duct, REVIT gives me static pressure loss as 7 inches. But calculated manually, I get to 0.5 inch. What is, in my opinion makes more sense. What's wrong ? I brought this issue to autodesk from my dealer and I am still waiting for an answer. Meanwhile, I have to do the pressure drop calculations manually. Which is very frustrating.
