Autodesk Revit MEP
- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Float this Topic to the Top
- Bookmark
- Subscribe
- Printer Friendly Page
3D Generic Zones in Revit/Revi t MEP
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Hi
I need to create a model that shows generic zones for my services. i.e. A model showing corridor 'extrusions' for ductwork, pipework, containment and a lighting zone, all shown as different colours. This is to show a conceptual design model/general routing of services.
I can only think of doing this using ductwork to represent each zone and applying filters for the colours and applying a medium detail level (to remove flanges etc), as the ductwork cannot look like ductwork and needs to look like an extrusion.
Does revit/revit mep have any functionality to provide general 3D zoning/extrusion, does anyone know of a better way to achieve the above?
Re: 3D Generic Zones in Revit/Revi t MEP
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
I would think an In-Place Mass would work for this purpose, maybe make them different materials to distinguish the different systems.
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Thanks, i am not familiar with masses. I have only seen 'create a new conceptual mass' option when you want to create a new file, could you point me in the right direction please?
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Sure, it's under the Architecture tab in 2012 (it's under Massing & Site in 2013), then In-Place Mass. Sketch it like you would an extrusion, then you can move it to the levels you want, and assign a material to it. I used different glass materials because of the transparency.
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
But bear in mind that it is good practice to create masses for each zone you are trying to indicate on each floor. you shouldn't copy the same in-place mass from one floor to another otherwise you will have problems when you come to edit them later on - as the design will undoubtedly change between now and then.
The intention of an in-place mass is that it is a "one-off" family that doesn't repeat in the model.
Please give Kudos as appropriate to enhance the value of these forums.
Thank you!
