• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Revit MEP Wishes
    Member
    schedule formatting in MEP?
    378 Views, 5 Replies
    04-26-2012 08:03 AM
    Does anyone know if there is a way to format the schedules in Revit MEP?  Our company has used Excel schedules (in ACAD) for many years...one of the nice things about them is the different formatting that can be used.  Large, bold text in the title, smaller text for information in the schedules, and the ability to add notes at the bottom.  I would very much appreciate any knowledge anyone has on this.  I have attached a PDF of what I'm talking about.
    Derek
    Please use plain text.
    *Expert Elite*
    Re: schedule formatting in MEP?
    04-26-2012 08:26 AM in reply to: dsarlo
    Here is a quick rundown of what aspects of your schedule's format can and cannot be accurately replicated in Revit:
    Schedule Title: The formatting (including font size) is tied to the field header's formatting. They should be separate. FAIL
    Header Alignment: You schedule shows the text being top-aligned. You cannot define a vertical justification in Revit. FAIL
    Body Text: You can format and align the font and fields just as your schedule does. YES!
    Notes/Remarks: This should be available just like it is for Panel Schedules. But alas, it is not. FAIL
    Dark Outer Border: Revit can assign a line style to the outer boundary of the schedule. YES!
    Internal Grid Lines: Revit can assign only a single line style to inner grid lines, so you cannot have darker horizontal lines. FAIL
    Corey D.        LogoEE.png   AutoCAD user  Revit user
    ⁞|⁞ Please use the Mark Solutions!.Accept as Solution and Give Kudos!Give Kudos functions as appropriate to further enhance the value of these forums. Thank you! ───────────────────────────────────────────────────────────────────────────────────────────
    Member
    04-26-2012 08:32 AM in reply to: CADastrophe
    hopefully "they'll" get around to this someday..?  I'm glad that the schedules already do what they do, just wish we could take it a few steps further to make them more presentable.
    Thnaks!
    *Expert Elite*
    04-26-2012 08:40 AM in reply to: dsarlo
    I wouldn't expect it anytime soon, "they" seem to only improve or change what "they" think needs to be. There are many posts here that request better schedule formatting and notes. This one, "Schedule Notes", goes back to 2008 and it hasn't even been acknowledged!
    I hope to be surprised someday...
    mark.silcock
    06-11-2012 02:18 PM in reply to: dsarlo
    Yes it is very frustrating when you have a bunch of families from different sources and some are have lowercase values, some have uppercase and some a bit of both. Schedules look like crap and you waste time modifying all the families to have the same formatting throughout. This should be possibel at the schedule end, maybe some schedule styles.... hmmm oh yeah sorry cant be like AutoCAD can we it might work then!
    Active Member
    10-18-2012 08:38 AM in reply to: dsarlo
    I thought I'd post this here in hopes "they'll" start paying attention. This seemed like the best place.
    I know I've seen a few posts on Vertical Schedules in my travels, so I'm going to add to the requests.
    Attached is an almost useable vertical schedule. As you can see Revit will allow you to turn a schedule on your sheet, and even turn the text within the Headings vertical instead of horizontal. But yet again, Revit FAILs to allow a user to customize the useful stuff. Why can't I turn the data vertical? Why can't I rotate the table in such a way that the headings are on the left and the data is on the right (without the text being upside down)?
    It's fine that we can't create a vertical scheudle easily, but at least make it possible to make one. It doesn't seem reasonable to have to make a horizontal schedule for 2 items that spans the length of a 36" page. I exaggerate a bit here, but still.
