• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Revit MEP Wishes
    Non-Selectable Links Setting
    180 Views, 3 Replies
    02-20-2012 04:21 AM
    I would like a right click feature when hovering over a link to make the link non-selectable. Just like how AutoCAD works with Excel files linked in. Filtering/pinning the links are good but non-selectable would be great!
    Please use plain text.
    *Expert Elite*
    Re: Non-Selectable Links Setting
    02-20-2012 08:04 AM in reply to: apaupert
    I absolutely agree with this, as well as most users would, I imagine.
    Discussed in this post is a work-around method of achieving this. However, this is NOT a solution, nor is it flawless.
    Corey D.        LogoEE.png   AutoCAD user  Revit user
    ⁞|⁞ Please use the Mark Solutions!.Accept as Solution and Give Kudos!Give Kudos functions as appropriate to further enhance the value of these forums. Thank you! ───────────────────────────────────────────────────────────────────────────────────────────
    New Member
    09-18-2012 01:02 PM in reply to: apaupert
    Bump!
    Can't believe this is still not implemented.
    Every person I've ever talked to working in MEP notes this as a significant annoyance.  After I set up arch/structural linked models and pin them, I NEVER want to select them again.
    Mis-clicks and the resulting 5-10 seconds of lost time happens every couple of minutes.  That is a big loss of efficiency.  Seems like a very easy fix to just add the unselectable option.
    Distinguished Contributor
    thombrady
    10-04-2012 01:37 PM in reply to: apaupert
    Everyone who uses REVIT, will ever want to use REVIT & those who are not even born yet want this feature. I cannot beleive how many times I cannot even select a duct or put a diffuser in because for some reason the link is preventing this! Please, Please implement this. Make it unselectable, if I want to select it I will open up the Link itself & do what I have to do then reload it back in.
