• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Revit MEP Wishes
    Distinguished Contributor
    Electrical Conduit
    365 Views, 17 Replies
    03-10-2009 08:12 AM
    We need electrical conduit in the worst sort of way. Plumbing has their pipes and mechanical has their duct, but if we are going to truly start modeling our systems in a truly BIM environment, we need the same sort of conduit that you would find in AutoCAD MEP.
    Please use plain text.
    Re: Electrical Conduit
    04-21-2009 12:12 PM in reply to: RedMan77
    Vote 2 of year 2009... I hope this gets into the priority items this time around! (Crossing my fingers)
    *BIM is in
    04-22-2009 04:18 AM in reply to: RedMan77
    Conduit is easy! Just create your conduit type as
    you would pipe types. Then create a workset called Electrical piping and make it
    curent when you draw. Draw your conduit in that workset and then turn the work
    set off in the other views. Thats what we do for all out piping needs such
    as electrical, med gas, etc. Make a workset for each.
    style="PADDING-RIGHT: 0px; PADDING-LEFT: 5px; MARGIN-LEFT: 5px; BORDER-LEFT: #000000 2px solid; MARGIN-RIGHT: 0px">
    Vote
    05-05-2009 11:07 AM in reply to: RedMan77
    But that is not the proper way to do it, the proper way is to have an actual conduit tool. I still say real conduit tools are a must.
    New Member
    05-14-2009 06:35 AM in reply to: RedMan77
    I agree we need electrical conduit. Using the pipe for plumbing is all well and good but the fittings are all different.
    Valued Mentor
    dennis
    05-19-2009 11:26 AM in reply to: RedMan77
    Another "gotcha" with your scenario is that if the file is linked, the Hosting file cannot make use of the Workset designations in the Linked file. (Unless I have missed something somewhere)
    06-13-2009 09:43 PM in reply to: RedMan77
    Yes - Conduit, we need it.
    But it won't be there till at least the next release
    So in the meantime - Pipes.
    Worksets for visability control though isn't great as you can't control worksets in view templates. The alternative is to add a parameter to the project for 'Pipe Use' - which you can then filter through
    07-13-2009 10:32 AM in reply to: RedMan77
    Conduit and wiring, NOT piping. Conduit and wiring. Other people use duct for faking in conduit also.
    Valued Mentor
    dennis
    07-20-2009 10:00 AM in reply to: RedMan77
    Use a FILTER called CONDUIT who search for components with the name CONDUIT in them. So you will create a PIPE TYPE called Conduit, and duplicate the elbows, tees, etc and rename them with Conduit, ie Conduit Elbow, Conduit Tee, and on and on. Then you can create a Filter that will look for Pipe Type that has the word Conduit in it.
    Works great, even tho it is a workaround. A true conduit object type would be better.
    07-20-2009 10:13 AM in reply to: RedMan77
    Absolutely!
