• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Revit MEP Wishes
    Valued Contributor
    tkendrick
    Conduit Service Type
    94 Views, 1 Replies
    07-30-2012 08:57 AM
    Once you apply a name to the Conduit Service Type, that name should continue on from the conduit. If you draw a section of conduit and end it, and continue it on that name should transfer to the new conduit you draw, I currently have to reselect the conduit network and re-type the servic type to apply it the entire run.
    Use this link to tell Autodesk about features you need:
    http://usa.autodesk.com/adsk/servlet/index?siteID=123112&id=1109794
    Please use plain text.
    Re: Conduit Service Type
    07-30-2012 09:30 AM in reply to: tkendrick
    This simple issue helps to illustrate the poor level of intelligence of the Conduit Systems.
    Corey D.        LogoEE.png   AutoCAD user  Revit user
    ⁞|⁞ Please use the Mark Solutions!.Accept as Solution and Give Kudos!Give Kudos functions as appropriate to further enhance the value of these forums. Thank you! ───────────────────────────────────────────────────────────────────────────────────────────
