• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Revit MEP Wishes
    Autodesk Professional Revit MEP Certification?
    839 Views, 15 Replies
    05-11-2012 09:14 AM
    It may exist and if it does I'd like to know where I can get this... But I'd like to see Autodesk Professional Revit MEP Certification. Right now it looks like there is certification that is totally focused on Architectural. I never bothered with this Certification because what I do for my company is only MEP and this certification means nothing to me as I NEVER deal with building a wall/floor/ceiling. I want a certification that shows what I know on only the MEP features. I could probably pass the Architectural Certification but why bother?
    Please use plain text.
    Valued Contributor
    tkendrick
    Re: Autodesk Professional Revit MEP Certification?
    05-15-2012 05:02 AM in reply to: apaupert
    Same here. Please add Revit MEP Certification.
    Use this link to tell Autodesk about features you need:
    Active Member
    jsousa
    05-15-2012 11:36 AM in reply to: apaupert
    Same here, there are tons of MEP only firms out there.
    Jason H. Sousa
    HPD, LLC
    Phone: 770-455-7707 Ext. 148
    E-mail: jsousa@hpdengineers.com
    Fax: 770-455-4532
    Valued Contributor
    tkendrick
    08-24-2012 09:11 AM in reply to: jsousa
    Wow! There must be more than THREE of us who use Revit MEP and want a certification for it.
    Bump!
    Distinguished Mentor
    asommer
    09-05-2012 10:58 AM in reply to: tkendrick
    I'd get certified.  What's there to certify in Architectural, anyway?
    Maybe they could use the User Status on these forums.  I see some people with "PRO".  I've been a "Distinguished Mentor" for a while.  Do I get a free Ice Cream?  1/2 price on my next pizza from Pizza Hut?
    Valued Contributor
    tkendrick
    09-05-2012 11:11 AM in reply to: asommer
    That's a good idea.
    I took the AutoCAD Certification. It's a practical type exam. Multiple choice, or fill-in answers, and you are presented with an image and description of what you need to do to find the answer. It's a test to see if you can use the basics of the software. Or at least for AutoCAD it was. I imagine the Revit Arch test is similar, you have to manipulate objects so you can produce the answer. Usually the answer was some form of dimension or property of an object.
    The tests aren't easy. I took the Professional test twice.
    Active Member
    09-18-2012 09:54 AM in reply to: apaupert
    I also work in an MEP only firm and this certification would likely be a good line on my AND my firms resume.
    All of my "professional" training came from Revit Arch.but all of the "real world" training was on MEP and I really feel MEP has a lot more depth to it. Maybe Autodesk is just waiting until more users work on Revit MEP, I know the Architectural industry has been in Revit for a good deal longer then MEP firms, then again maybe the Arch test is just more cost effective to produce because there isnt much to it.:smileyvery-happy:
    New Member
    10-08-2012 02:18 AM in reply to: apaupert
    this is in high demand...Why is this not available for Revit MEP? or maybe i should ask..."WHEN" will this be available?
    Member
    01-11-2013 10:20 AM in reply to: apaupert
    I also work for a MEP contractor. i've been using Revit MEP for the last 4 years, and having a certification to validate my experience would be great. i know that i could pass the Architectural test too, but don't see any value in that at this point.
    Member
    02-08-2013 06:30 AM in reply to: apaupert
    Yeah, please add Revit MEP Professional cert :smileyhappy:
