Autodesk Revit Architecture
Topic Options
- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Float this Topic to the Top
- Bookmark
- Subscribe
- Printer Friendly Page
wall sweep modificati on in 3D view
Options
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
335 Views, 1 Replies
12-21-2012 12:08 PM
Revit 2013 does not have the Wall Sweep panel available from a 3D view.
How do I go about modifying segments?
Specifically, how do I modify the sweep so it wraps both sides and end of the wall?
Re: wall sweep modificati on in 3D view
Options
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
12-21-2012 12:26 PM in reply to:
ChristineMarie
Do you have update release 2 installed? This looks like an issue related to .NET 4.5 being installed and causing trouble with the context panels. If you have recently installed software which updated the .NET framework on your computer to 4.5 and you don't have the Revit update release 2 installed you will see problems like this.
http://usa.autodesk.com/adsk/servlet/ps/dl/item?si
Jeff Hanson
Sr. Subject Matter Expert
Autodesk, Revit User Experience
