• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Revit Architecture
    *Dustin
    wall end condition?
    641 Views, 4 Replies
    05-27-2010 07:40 AM
    So I have a curved wall meeting up with a curved/angled curtain wall system.
    What is the trick to angle out the end of the wall so it will butt up with
    the curtain wall?
    thanks
    Please use plain text.
    *cdv
    Re: wall end condition?
    05-27-2010 07:48 AM in reply to: *Dustin
    Go to the elevation that shows the side of masonry wall, click on the wall
    then in the ribbon click edit profile, once in edit mode draw a line at the
    same angle of the curtain wall, trim/extend the upper and lower lines to the
    newly created line, erase the vertical line representing the old wall edge
    and you are done .
    "Dustin" wrote in message
    news:6398553@discussion.autodesk.com...
    > system. What is the trick to angle out the end of the wall so it will butt
    > up with the curtain wall?
    > thanks
    *Dustin
    05-27-2010 08:03 AM in reply to: *Dustin
    tried that and I do not get the edit profile option with the curved brick
    wall
    "cdv" wrote in message
    news:6398543@discussion.autodesk.com...
    and you are done .
    > thanks
    *Brian Winterscheidt
    05-27-2010 08:09 AM in reply to: *Dustin
    > wall
    Make the masonry wall longer, use an in-place void to remove the portion
    below the curtain wall.
    Brian Winterscheidt
    LWPB Architecture
    Oklahoma City, Oklahoma
    *Dave Jones
    05-27-2010 08:20 AM in reply to: *Dustin
    > and you are done .
    will that work if the face plane of the curtain wall is curved? You
    wouldn't be able to use a line for the trim/extend...
    Dave - DDP
    Acad 2011 and Revit 2011
    Win 7 Pro 64 bit
    Intel I7-860 @2.8GHz
    12GB DDR3 RAM
    GeForce GTX260
