• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Revit Architecture
    Active Member
    ppesce
    volume creating error
    118 Views, 4 Replies
    03-07-2012 06:33 AM
    I created a  volumetric mass and then i tried to put a roof on a upper surface curvilinear very complex, it got error on application roof and i'm not able to resolve
    Please use plain text.
    *Expert Elite*
    Alfredo_Medina
    Re: volume creating error
    03-07-2012 07:17 AM in reply to: ppesce
    Image, please?
    Planta1 Revit Online Consulting | info@planta1.com
    Active Member
    ppesce
    03-08-2012 12:55 AM in reply to: Alfredo_Medina
    i send the image, if possible to try a solution i'd mail the file revit by e-mail because the file is too large
    *Expert Elite*
    Alfredo_Medina
    03-08-2012 07:35 AM in reply to: ppesce
    It is difficult to understand the form by just one image, but it does not seem "very complex" as you said. Sometimes, "Roof by face" does not work on these forms, though. But you have the other alternative: "Wall by face" (a thin wall) which usually works well with these forms.
    See attached illustration.
    Active Member
    ppesce
    03-09-2012 04:12 AM in reply to: Alfredo_Medina
    thank you!!
    I resolve it in one part of the roof, in the other part I have cutted the mass and goes ok, but I think Autodesk will try to improve in the next Revit versions
    hallo from Italy
