• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Revit Architecture
    text disappears during plotting
    153 Views, 4 Replies
    08-28-2012 07:13 AM
    Hopefully someone else has run across this and has an answer.
    I'm plotting multiple sheets in revit 2011 (doesn't matter if it's 2 or 20,)the first sheet comes out fine, but all the rest has text / annotation that has disappered.  Text in the title block, elevation markers, section markers, and column bubbles.  The markers appear, but the text doesn't.  Anybody know why?  My work around currently is to plot to pdf and then plotting the pdf.  But this is a step that I shouldn't have to do.
    Please use plain text.
    Valued Mentor
    Re: text disappears during plotting
    08-31-2012 05:01 AM in reply to: jdukc
    What are you plotting to?
    I had a similar problem plotting to a KIP.  It turned out that KIP updated some drivers for Windows 7 and Revit that took care of it.
    Product Support
    fernanda.firman
    08-31-2012 09:05 AM in reply to: jdukc
    Please let us know what plotter you are using.
    Have you updated the printer's drivers?
    Fernanda Lima Firman
    Revit Support Specialist
    Autodesk, Inc.
    Revit Clinic
    If this helped solve your issue - remember to 'accept as solution' to help others find answers.
    08-31-2012 10:22 AM in reply to: fernanda.firman
    plotter is HP Designjet 4500 and yes, I updated the drivers.  The text is disappearing on all machines here.
    Valued Mentor
    08-31-2012 11:13 AM in reply to: jdukc
    HP.  They have that Universal print driver that isn't so good.  We had to roll back to an older Post Script driver to get that work properly for our 1200 DesignJets.
