• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Revit Architecture
    Member
    Accepted Solution
    suggestions for revit
    240 Views, 5 Replies
    03-05-2013 01:28 PM
    A few small changes that would help revit speed and functionality immensley:
    1. If you are in a detail view, could you please add the option "add to sheet" to the right click menu. It would save an immense amount of time from the current drag and drop options.
    2.  a simple hyperlink tool that would allow you to make "smart" references to drawings in notes and schedules that would be self-updating.
    3. A option to automatically number details as they are placed and rearranged on sheets such as "begin numbering bottom/top right/left"
    Thank you!
    Please use plain text.
    *Expert Elite*
    Alfredo_Medina
    Re: suggestions for revit
    03-05-2013 05:06 PM in reply to: neilparrish
    I think your wish # 2 already exists (not for schedules but for other views). It's the View Reference tool.
    Planta1 Revit Online Consulting | info@planta1.com
    Member
    03-06-2013 10:50 AM in reply to: neilparrish
    So it does.  Thank you for pointing that out!  Ask and you shall receive.
    If I am just ignoring the other 2 as well, please let me know.
    Thank you for the help,
    NP
    Member
    03-06-2013 11:35 AM in reply to: Alfredo_Medina
    One question about the view reference tool you pointed out.  We have tried to set up a tag that displays the drawing number and sheet reference and for some reason the origin point is set 4-6" below the text. As a result, when you go to move the family once it is imported into the project, you cannot simply grab it without zooming out and finding the origin.  Both reference planes in the family have the box used to define origin checked although it is greyed out.  Any advice you can offer would be much appreciated.
    Thank you,
    NP
    *Expert Elite*
    Alfredo_Medina
    03-06-2013 12:25 PM in reply to: neilparrish
    Yes, unfortunately, that family has that issue, and the distance of that origin point to the reference varies depending on the scale of the view. It's not something that the user can modify.
    Member
    03-06-2013 01:30 PM in reply to: Alfredo_Medina
    Nonetheless it is still a very helpful tool. Thank you for repsonding.
