• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Revit Architecture
    New Member
    suddenly can't access my central file
    114 Views, 3 Replies
    10-02-2012 07:57 AM
    came in to work this morning and have not been able to open my project file in revit.  Tried restarting revit several times.  tried shuting down and restarting computer several times.  no help.  I can open a new file in revit no problem, it seems to only be the project file.  my team members are not having this issue, it's just my computer.  It will load to about 95% and then stop responding.  any ideas before i uninstall and reinstall revit?????
    Please use plain text.
    *Expert Elite*
    Alfredo_Medina
    Re: suddenly can't access my central file
    10-02-2012 09:13 AM in reply to: kenbaviello
    Are you opening your existing local copy, or opening the central with "create local copy" activated (recommended) to orverwrite your old local copy?
    Planta1 Revit Online Consulting | info@planta1.com
    New Member
    10-02-2012 09:30 AM in reply to: Alfredo_Medina
    thanks for responding.. i'm doing the later... openign central and creating new local copy (overwriting the old)....
    *Expert Elite*
    Alfredo_Medina
    10-02-2012 09:39 AM in reply to: kenbaviello
    Did you try login on your own computer as a different user, and try to open the central again?
