• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Revit Architecture
    Active Contributor
    a06vsh
    Accepted Solution
    spot elevations stopped working?!?
    208 Views, 5 Replies
    03-05-2013 12:50 AM
    I have a topography model that I've been working with for a while now, and all of a sudden the spot elevation stopped working. I have one spot elevation that works, that i can move around and it'll change to the right plus height. But as soon as i try to make a new one it just says -0.05 no matter where i put it except for if i hover over a stair, then it displays the correct plus height.
    I'm confused.
    Anyone knows what might have gone wrong?
    Please use plain text.
    *Expert Elite*
    Alfredo_Medina
    Re: spot elevations stopped working?!?
    03-05-2013 05:06 AM in reply to: a06vsh
    It could be that the topography is located above the top plane and cut plane of the current view. By default, these planes are at 200'. If the site is at a higher elevation, the spot elevation tool won't be able to "see" the topography. Look in an elevation view if this is the case, and if it is, raise the values of the top and cut plane in the site view and try again.
    Planta1 Revit Online Consulting | info@planta1.com
    Active Contributor
    a06vsh
    03-14-2013 01:10 AM in reply to: Alfredo_Medina
    Already checked and that's not the case. Also, I have one old spot elevation that works, if I move that one around it shows the right height, but any new ones or copies of that old one show -0.5.
    Valued Mentor
    03-14-2013 02:14 AM in reply to: a06vsh
    check if, by mistake the type properties of spot elevations was changed ...it could became,  by mistake Relative
    • select the spot elvation marker
    • from Properties> Edit Type >Text > Elevation Origin ....There are three options there: Project, Shared and Relative...normaly for terrain I use Shared as absolute values or Project if I want to refer to the building levels
    • If Relative is active then the spot elevations refers to a certain level and from Properties you can control the Constrain>Relative Base
    Active Contributor
    a06vsh
    03-14-2013 02:18 AM in reply to: constantin.stroescu
    all of a sudden, 2 weeks later, they're working again. Good old Revit bugs :smileyhappy:
    Thanks for the suggestions though, will keep them in mind for future issues!
    Valued Mentor
    03-14-2013 02:22 AM in reply to: a06vsh
    see also if it is not here the cause :
    select the spot elevation  in Properties> Text >Display Elevations...you have here some options..Bottom, Top....
