• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Autodesk Revit Architecture
    section lines??
    141 Views, 2 Replies
    09-15-2004 02:41 PM
    When i draw a section line it goes through the whole design.
    is it possible to show only the section head and some cm of dashdot line and the same on the other side of the design?
    because if you create a number of section views your drawing will be full of section lines.
    thanks,
    mike
    Please use plain text.
    Distinguished Contributor
    Re: section lines??
    09-15-2004 03:07 PM in reply to: mthemelis
    You can pick on the section and you will see a break mark in the section line, click that and it splits the section line, then gives you grips to stretch the line as big or small as you wish.
    you can also select multiple head/tail styles in the properties of the section line and create as many types as you want. You can also right click on any section line andsay hide annotation in view.
    *Frame
    Re: section lines??
    09-16-2004 09:54 AM in reply to: mthemelis
    Also, sections have a property "hide at views coarser than" which will keep the section from showing up in views with "coarse" scales. i.e. you may not want all your walls sections showing up in an 1/8" plan, but you do want your building sections to show up. "sdbrown" wrote in message news:10515684.1095286096176.JavaMail.jive@jiveforum1.autodesk.com... > You can pick on the section and you will see a break mark in the section line, click that and it splits the section line, then gives you grips to stretch the line as big or small as you wish. > you can also select multiple head/tail styles in the properties of the section line and create as many types as you want. You can also right click on any section line andsay hide annotation in view.
