• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Revit Architecture
    Member
    round mullions in ornamental courtyard gate
    117 Views, 2 Replies
    12-10-2012 10:20 AM
    I have to create a decorative Gate for a building,
    I tried to use a curtainwall but I can't figure out how to make a round mullion or an angled mullion.
    Can anyone help??
    The shape is basically a circle with an X thru it inside a square, that repeats several times.
    Please use plain text.
    Alfredo_Medina
    Re: round mullions in ornamental courtyard gate
    12-10-2012 12:32 PM in reply to: bhpka
    Yes, custom shapes for mullions are possible, round, angled,...  You need to define a closed shape that Revit can understand as the sketch for an extrusion using the curtain mullion profile template. Once you open the template, there will be some messages that explain how Revit "cuts" the panel when it intersects the profile.
    Planta1 Revit Online Consulting | info@planta1.com
    12-10-2012 01:25 PM in reply to: bhpka
    You might also consider using a Railing, and create a custom Baluster Family for the gate.
    If the Gate needs to swing like a door, you might also consider using a custom Door Family inside the curtainwall
    as you first suggest.
    A nice trick is you can highlight the curtain panel using the Tab key, then replace it with either a custom curtain wall door, or-- replace it with a Wall ( Duplicate a wall type and create a new one with a very thin thickness ).
    You can then insert a "normal" door into the curtainwall--into the "wall" that is in place of the curtain panel.
    Cliff B. Collins
    Registered Architect/BIM Manager
    Thalden Boyd Emery Architects
    St. Louis, MO
