• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Revit Architecture
    Active Member
    revit to sketchup
    1873 Views, 22 Replies
    04-12-2012 03:27 PM
    So i have designed in revit this beautiful building for my thesis project and it is very curvy and i have tried several different ways to import it into sketchup but every time i do the buildings curves are such a mess that i can't even work with it. Is there a way to import without loosing the design? please help!
    Please use plain text.
    Valued Mentor
    vector2
    Re: revit to sketchup
    04-12-2012 04:20 PM in reply to: sabtf7
    SketchUp doesn't do curves.
    Active Member
    04-12-2012 04:39 PM in reply to: vector2
    Is there a way to make my building into a component or something.. There must be some kind of setting to help it export as a simplified curve right?
    Valued Mentor
    vector2
    04-12-2012 04:47 PM in reply to: sabtf7
    "a way to make my building into a component"
    Please explain in more ways than one what you mean by that.
    Active Member
    04-12-2012 05:05 PM in reply to: vector2
    I just started using revit about a month ago so I don't know any of the tricks or techniques to making a building more simplified in terms of file size, or grouping walls so they stick together. When I say massing I mean importing what I have as one object so that if I were to import it into sketchup it wouldn't freak out on me because the building would be one large piece. On another note would it help if I exported my revit file to another program before importing it to sketchup or are there any buttons I can click to help the export better define the curved geometry.
    parveen.revit
    04-12-2012 10:45 PM in reply to: sabtf7
    have you tried exporting DWG, DXF, DWF, FBX file format out of Revit (with solid and wiremesh options).
    Then try to import/open those into SketchUp.
    Parveen_Intec_Infocom (BIM, CAD, GIS, QS Services' Provider)
    Active Member
    04-16-2012 09:11 AM in reply to: sabtf7
    How and where exactley do I go to do that that sounds promising?
    *Expert Elite*
    Alfredo_Medina
    04-16-2012 09:18 AM in reply to: sabtf7
    Big R > Export > CAD Formats.
    Planta1 Revit Online Consulting | info@planta1.com
    Active Member
    04-16-2012 09:22 AM in reply to: Alfredo_Medina
    yeah i got that part.  From there how do i edit my export to be a solid or wire mesh to help fix the curves so when i export they will come in as solid forms or masses in sketchup?
    *Expert Elite*
    04-16-2012 09:27 AM in reply to: sabtf7
    see attached.
    Cliff B. Collins
    Registered Architect/BIM Manager
    Thalden Boyd Emery Architects
    St. Louis, MO
